    Are you working from home?
Samsung ProXpress SL-C2670 Color Laser MFP - Clearing Original Document Jams
When an original document jams in the document feeder, a warning message appears on the display.
To avoid jams, refer to the following guidelines:
  • Ensure that the adjustable guides are positioned correctly.
  • Do not overload the tray.
  • Ensure that the paper level is below the paper capacity mark on the inside of the tray.
  • Flex, fan, and straighten paper before loading.
  • Do not remove paper from the tray while your printer is printing.
  • Do not use creased, damp, or highly curled paper.
  • Do not mix papers in a tray.
  • Use only recommended print media.
  • To prevent document jams, use the scanner glass for thick, thin, or mixed paper-type originals.
Clear original document jams
When an original document jams while passing through the document feeder, a warning message appears on the display.
