Samsung ML-216x, ML-216xW Laser Printers - Clearing Paper Jams
This document provides instructions on how to clear a paper jam in the printer.
When a paper jam occurs, the status LED on the control panel lights orange. Use the instructions in this topic to find and remove the jammed paper.
Turn off the printer before clearing paper jams
Because printer models and options vary, the illustrations used in this document might look slightly different from your printer.
Clear paper jams
Paper jams can occur in several parts of the printer. Go to the appropriate section to resolve the paper jam.
To avoid tearing the paper, pull the jammed paper out slowly and carefully. Follow the instructions in the following sections to clear the jam.
Tips for avoiding paper jams
  • Make sure that the adjustable guides are positioned correctly.
  • Do not overload the tray. Make sure that the paper level is below the paper capacity mark on the inside of the tray.
  • Do not remove paper from the tray while your machine is printing.
  • Flex, fan, and straighten paper before loading.
  • Do not use creased, damp, or highly curled paper.
  • Do not mix paper types in a tray.
  • Use only recommended print media (see "Print media specifications" in the User Guide).
