    Fix Windows 10 Update Issues
    Are you working from home?
Samsung ML-216x, ML-216xW Laser Printers - Replacing the Toner Cartridge
The document explains how to replace the toner cartridge.
When the toner cartridge has reached the end of its estimated cartridge life, the printer stops printing. Also, the Smart Panel program window appears on the computer to replace the cartridge.
Replacing the toner cartridge
Use these steps to replace the toner cartridge. Before you begin, make sure the output support is closed.
  1. Open the top cover of the printer.
    Figure : Example of opening the printer cover
  2. Pull the toner cartridge out.
    Figure : Example of pulling the toner cartridge out
    To recycle the toner cartridge, see Product Returns and Recycling
  3. Take a new toner cartridge out of its package and remove the protective cap.
    Do not touch the drum located in the toner cartridge or imaging unit. Use the handle on the cartridge to avoid touching this area.
    Figure : Example of removing the protective cap
  4. Slowly shake the cartridge side to side five or six times to distribute the toner evenly inside the cartridge. This will assure maximum copies per cartridge.
    Figure : Example of gently shaking the toner cartridge
    If toner gets on clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
  5. Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
    Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
    Figure : Example of inserting the toner cartridge
  6. Close the top cover. Make sure that the cover is securely closed. If the cover is not firmly closed, printing errors may occur when you print.
    Figure : Example of closing the printer cover
