Samsung CLX-2160 Color Laser MFP - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge for the Samsung CLX-2160 Color Laser Multifunction Printer.
The printer uses four colors and has a different toner cartridge for each one: yellow (Y), magenta (M), cyan (C), and black (K).
When the toner cartridge is completely empty:
  • The Status LED and the toner-related message on the display indicate when each individual toner cartridge should be replaced.
  • The printer stops printing.
At this stage, the toner cartridge needs to be replaced.
Replacing the toner cartridges
Use these steps to replace the toner cartridges.
  1. Turn the printer off, then wait a few minutes for the printer to cool.
  2. Open the front cover.
  3. Pull the corresponding toner cartridge out.
    Figure : Example of pulling out the appropriate toner cartridge
  4. Take a new toner cartridge out of its package.
  5. Insert the toner cartridge into the correct slot.
  6. Remove the cartridge cap.
    Figure : Example of removing the cartridge cap
    If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
  7. Grasp the toner cartridge and align it with the corresponding slot inside the printer. Insert it into its slot until it clicks into place.
    Figure : Example of grasping the toner cartridge, and inserting back into corresponding slot
  8. Close the front cover. Make sure that the cover is securely latched and then turn the printer on.
    If the front cover is not completely closed, the printer will not operate.
    If the installation is completed properly, a guide report is printed out automatically. Wait for about 1.5 minutes for the printer to get ready.
