    Fix Windows 10 Update Issues
    Are you working from home?
Samsung Xpress SL-M3015 Laser Printer - Loading Paper
This document provides instructions on how to load paper into the printer for the Samsung Xpress SL-M3015 Laser Printer.
Illustrations in this user’s guide may differ from your printer depending on the model and options installed.
Printing on special media
The paper setting in the printer and driver should match to print without a paper mismatch error.
  • When printing on a special media, we recommend you feed one paper at a time. Check the maximum input number of media for tray.
  • Printing the special media (Face up): If special media are printed out with curl, wrinkles, crease, or black bold lines, open the rear cover and try printing again. Keep the rear cover opened during printing.
Refer to the table for special media uses in the tray.
Types
Tray
Manual feeder
Plain
Thick
Thicker
Thin
Bond
Color
Cardstock
Labels
Transparency
Envelope
Thick Envelope
Preprinted
Recycled
Cotton
Archive
(·: Supported, Blank: Not supported)
You change the paper setting set in the printer from Samsung Easy Printer Manager™ program or SyncThru™ Web Service.
  • If your printer is connected to the local, you can set the printer’s setting from Samsung Easy Printer Manager >Advanced Setting > Device Settings.
  • If your printer is connected to the network, you can set the printer’s setting from SyncThru™ Web Service > Settings tab > Machine Settings.
