    Are you working from home?
Samsung Xpress SL-M267x, SL-M287x, SL-M288x Laser MFP - Loading Originals
This document explains how to load paper in the tray.
Users can use the scanner glass or the document feeder to load an original for copying, scanning, and sending a fax.
On the scanner glass
Using the scanner glass, users can copy or scan originals. Users can get the best scan quality, especially for colored or gray-scaled images. Make sure that no originals are in the document feeder. If an original is detected in the document feeder, the printer gives it priority over the original on the scanner glass.
  1. Lift and open the scanner lid.
    Figure : Scanner lid, open
  2. Place the original face down on the scanner glass. Align it with the registration guide at the top left corner of the glass.
    Figure : Place original, face down
  3. Close the scanner lid.
  • Leaving the scanner lid open while copying might affect copy quality and toner consumption.
  • Dust on the scanner glass might cause black spots on the printout. Always keep it clean.
  • If users are copying a page from a book or magazine, lift the scanner lid until its hinges are caught by the stopper and then close the lid. If the book or magazine is thicker than 30 mm, start copying with the scanner lid open.
  • Be careful not to break the scanner glass. Users might get hurt.
  • Do not put hands while closing the scanner lid. The scanner lid might fall on a user's hands and get hurt.
  • Do not look into the light from inside of the scanner while copying or scanning. It is harmful to the eyes.
In the document feeder
Using the document feeder, users can load up to 40 sheets of paper (80 g/m2, 21 lbs. bond) for one job.
  1. Flex or fan the edge of the paper stack to separate the pages before loading originals.
    Figure : Flex or fan paper
  2. Load the original face up into the document feeder input tray. Make sure the bottom of the original stack matches the paper size marked on the document input tray.
    Figure : Load original, face up
  3. Adjust the document feeder width guides to the paper size.
    Figure : Width guides, adjust
    • Dust on the document feeder glass might cause black lines on the printout. Always keep the glass clean.
    • To print on both sides of the paper using the ADF, from the control panel press (Copy) > (Menu) > Copy Feature > Duplex > 1 -> 2 Sided or 1 -> 2 Sided Rot, and print on one side of the paper, then reload the sheet to print on the other side.
    • Duplex printing might not be available for some models.
