    Fix Windows 10 Update Issues
    Are you working from home?
Samsung Xpress SL-M3015 Laser Printer - Clearing Paper Jams
This document provides instructions on how to clear a paper jam in the printer.
By selecting the correct media types, most paper jams can be avoided. To avoid paper jams, refer to the following guidelines:
  • Ensure that the adjustable guides are positioned correctly.
  • Do not overload the tray. Ensure that the paper level is below the paper capacity mark on the inside of the tray.
  • Do not remove paper from the tray while your printer is printing.
  • Flex, fan, and straighten paper before loading.
  • Do not use creased, damp, or highly curled paper.
  • Do not mix papers type in a tray.
  • Use only recommended print media.
Depending on your printer model and its options, the illustrations used in this document might be different.
Turn off the printer when clearing jams from the printer.
Clear paper jams
Paper jams can occur in several parts of the printer. Go to the appropriate section to resolve the paper jam.
