Samsung MultiXpress SL-M4370, SL-M5370 Laser Multifunction Printers - Loading Paper
This document provides instructions on how to load paper into the paper tray.
If you do not adjust the guide, it may cause paper registration, image skew, or paper jams.
  warning:
Using photographic paper or coated paper may cause problems, that require repairs. Such repairs are not covered by the warranty or service agreements.
Printing on special media
The paper setting in the printer and driver should match to print without a paper mismatch error.
To change the paper setting set in the printer, from SyncThru™ Web Service click Settings tab > printer Settings > System > Input Tray.
Or, you can set it from the control panel. Then, set the paper type from the Printing preferences window > Paper tab > Paper Type. For example, if you want to print on labels, select Labels for Paper Type.
When using special media, feed one sheet at a time.
Refer to the table for special media uses in the tray.
Types
Standard tray/second cassette feedera
High Capacity Feedera
Multi-purpose tray
Plain
Thick
Thin
Bond
Cotton
Envelope
· (ISO B5, Monarch, DL, C5, C6, No 10 only)
Color
Cardstock
Labels
Preprinted
Recycled
Archive
Punched
Letterhead
a. optional device
(·: Supported, Blank: Not supported)
The media types are shown in the Printing Preferences. This paper type option allows you to set the type of paper to be loaded in the tray. This setting appears in the list so that you can select it. This will let you get the best quality printout. If not, the desired print quality may not be achieved.
