Samsung Xpress SL-C48x Color Laser MFP - Clearing Paper Jams
The following procedures show how to clear paper jams.
In tray
  • To avoid tearing the paper, pull the jammed paper out slowly and gently.
  • Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type.
  1. Remove the cassette tray.
    Figure : Cassette tray, remove
  2. Remove the jammed paper by gently pulling it straight out.
    Figure : Paper, remove
  3. Reinstall the cassette tray.
    Figure : Cassette tray, install
  4. Open the front door.
    Figure : Front door, open
  5. Close the front door.
    Figure : Front door, close
Inside the printer
The fuser area is hot. Take care when removing paper from the printer.
  1. Open the rear cover door.
    Figure : Rear cover door, open
  2. Open the frame-transfer.
    Figure : Frame-transfer, open
  3. Remove the jammed paper by gently pulling it straight out.
  4. Close the frame-transfer.
    Figure : Frame-transfer, close
  5. Close the rear cover door.
    Figure : Rear cover door, close
  6. Make sure the rear cover door clicks in place.
    Figure : Rear cover door, click
In the exit area
  1. Open the scanner unit.
    Figure : Scanner unit, open
  3. Close the scanner unit.
    Figure : Scanner unit, close
