Samsung Xpress SL-C460, SL-C462, SL-C463, SL-467 Color Laser MFP - Clearing Paper Jams
This document shows you how to clear a paper jam in the printer. When a paper jam occurs, a warning message displays on the control panel.
To avoid tearing the paper, pull the jammed paper out gently and slowly. Follow the instructions in the following sections to clear the jam.
Jam in tray 1
If paper is jammed in tray 1, use these steps to release the jammed paper.
  1. Pull out tray 1.
    Figure : Pull out tray 1
  2. Remove the jammed paper by gently pulling it straight out.
    Figure : Remove the jammed paper
  3. Insert tray 1 back into the printer until it snaps into place.
    Figure : Insert tray 1
  4. Open and close the front cover. Printing automatically resumes.
    Figure : Open and close the front cover
Jam inside the printer
If paper is jammed inside the printer, use the steps to release the jammed paper.
The fuser area is hot. Be careful when removing paper from the printer.
  1. Open the rear cover door.
    Figure : Open the rear cover door
  2. Open the frame-transfer.
    Figure : Open the frame-transfer
  3. Remove the jammed paper by gently pulling it straight out.
  4. Close the frame transfer.
    Figure : Close the frame transfer
  5. Close the rear cover door, pushing it until it snaps into place.
    Figure : Close the rear cover door
Jam in the exit area
If paper is jammed in the exit area, use the steps to release the jammed paper.
  1. Open the scanner unit.
    Figure : Open the scanner unit
  3. Close the scanner unit.
    Figure : Close the scanner unit
