Samsung SCX-5835, SCX-5935 Laser MFP - Clearing Original Document Jams
This document shows you how to clear a paper jam in the printer. When an original document jams while passing through the document feeder, a warning message displays on the control panel.
To prevent document jams, use the scanner glass for thick, thin, or mixed paper-type originals.
To avoid tearing the document, pull out the jammed document gently and slowly.
