    Apache Log4j Update
Samsung Laser Printers - Clearing Paper Jams
This document applies to the Samsung SCX-465xN, 4321NS, 4621NS, 465xF, 4521FX, 4521HS, 465xFN, 465xHN, 4521NS, 4821HN series printers.
This document shows you how to clear an original document jam in the printer. When an original document jams while passing through the document feeder, a warning message displays on the control panel.
To avoid tearing the document, remove the jammed document gently and slowly.
To prevent document jams, use the scanner glass for thick, thin, or mixed paper-type originals.
Clear paper jams
Paper jams can occur in several parts of the printer. Go to the appropriate section to resolve the paper jam.
To resume printing after clearing paper jams, open and close the access door.
