    Apache Log4j Update
Samsung SCX-4701, SCX-4725F, SCX-4726FD Laser MFP - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge. When a toner cartridge has reached the end of life, the printer will stop printing.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Lift the control panel (1), then open the front cover (2).
    Figure : Open the front cover
  2. Pull the toner cartridge out of the printer.
    Figure : Remove the used toner cartridge
  3. Remove the new toner cartridge from its packaging.
    Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the toner cartridge.
    Figure : Unpack the replacement toner cartridge
  4. Remove the paper protecting the toner cartridge.
    Figure : Remove the protective paper
  5. Slowly shake the toner cartridge five or six times to distribute the toner evenly inside the toner cartridge. It will assure maximum copies per toner cartridge.
    Figure : Rock the toner cartridge gently side to side
    If toner gets on clothing, wipe it off with a dry cloth and wash it in cold water. Hot water sets toner into fabric.
    Do not touch the green underside of the toner cartridge. Use the handle on the toner cartridge to avoid touching this area.
  6. Hold the toner cartridge by the handle and slowly insert it into the opening in the printer.
    Figure : Install the replacement toner cartridge
  7. Close the front cover (1), and return the control panel to its original position (2).
    Figure : Close the front cover
