    Apache Log4j Update
Samsung SCX-4600, SCX-4623 Laser MFP - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge.
When the toner cartridge has reached its estimated cartridge life:
  • End of life Replace new cart displays on the control panel.
  • The printer stops printing. Incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced. Check the type of toner cartridge for your printer.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Open the front door.
  2. Pull the toner cartridge out of the printer.
    Figure : Remove the used toner cartridge
  3. Remove the new toner cartridge from its packaging.
  4. Remove the paper protecting the toner cartridge by pulling the packing tape.
    Figure : Remove the protective paper
  5. Locate the sealing tape at the end of the toner cartridge. Carefully pull the tape completely out of the toner cartridge and discard it.
    Figure : Remove the sealing tape
    • The sealing tape should be longer than 60 cm (23.6 inches) when correctly removed.
    • Holding the toner cartridge, pull the sealing tape straight to remove it from the toner cartridge. Be careful not to cut the tape. If this happens, you cannot use the toner cartridge.
    • Refer to the helpful pictures on the toner cartridge wrapping paper.
  6. Slowly shake the toner cartridge five or six times to distribute the toner evenly inside the toner cartridge. It will assure maximum copies per toner cartridge.
    Figure : Rock the toner cartridge gently side to side
    If toner gets on clothing, wipe it off with a dry cloth and wash it in cold water. Hot water sets toner into fabric.
    Do not touch the green underside of the toner cartridge. Use the handle on the toner cartridge to avoid touching this area.
  7. Hold the toner cartridge by the handle and slowly insert it into the opening in the printer.
    Tabs on the sides of the toner cartridge and corresponding grooves within the printer will guide the toner cartridge into the correct position until it locks in place.
    Figure : Install the replacement toner cartridge
  8. Close the front door, making sure the cover is securely closed.
