    Are you working from home?
HP Notebook - 14-bs011nt Product Specifications
2BT04EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ 520 Graphics (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
35.56 cm (14") diagonal HD display
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 VGA; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
34 x 24 x 2.37 cm
1.9 kg
65 W AC power adapter
Battery life mixed usage
Up to 12 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 30 minutes
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
