    Fix Windows 10 Update Issues
    Are you working from home?
Document ID: c05854229
Version: 1
Advisory: HP ZBook x2 G4 Detachable Workstation - HP Elite USB-C Dock May Not Be Detected After Resuming From Hibernation
Release date : 07-Dec-2017
Last updated : 11-Dec-2017
DESCRIPTION
When plugging the HP Elite USB-C Dock in HP ZBook x2 G4 Detachable Workstation while resuming from hibernation, the system may have following errors:
  • No detection of HP Elite USB-C Dock
  • Intel USB 3.1 eXtensible Host Controller appears with a yellow exclamation mark in Windows Device Manager
SCOPE
Systems:
  • HP ZBook x2 G4 Detachable Workstation
Operating Systems:
  • Microsoft Windows 10 RS2
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 Enterprise (64-bit)
RESOLUTION
To resolve this issue, unplug the HP Elite USB-C Dock and plug it back in.
To avoid this issue, make sure not to plug the HP Elite USB-C Dock in while resuming from hibernation.
Hardware platforms affected : HP ZBook x2 G4 Detachable Workstation
Support Communication Cross Reference ID : IA05854229
