Samsung Laser Printers - Replacing the Toner Cartridge
The following procedure shows how to replace the toner cartridge.
The printer uses four colors and has a different toner cartridge for each one: yellow (Y), magenta (M), cyan ©), and black (K). When the toner cartridge is totally empty:
  • The status LED turns red on and the display screen shows the error message of replacing toner.
  • The printer stops printing and incoming faxes are saved in memory. However, when the color toner cartridges are empty, but there is toner left in the black toner cartridge, users can still print black-and-white print jobs (the submitted job must be in black and white).
  • Check the type of the toner cartridge for the printer.
At this stage, the toner cartridge needs to be replaced.
  1. Open the front door.
    Figure : CLX-92x1/93x1 series
    Figure : SCX-812x series
  2. Pull the corresponding toner cartridge out from the printer.
  3. Remove the new toner cartridges from its bag.
  4. Thoroughly roll the cartridge five or six times to distribute the toner evenly inside the cartridge.
  5. Carefully pull the sealing tape out of the toner cartridge.
    If toner gets on any clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
  6. Hold the toner cartridge and align it with the corresponding slot inside the printer. Insert it back into its slot until locks in place.
  7. Close the front door. Make sure the door is securely closed.
    If the front door is not completely closed, the printer will not operate.
