HP ENVY x360 - 15-bp098nf Product Specifications
1UK83EA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
12 GB DDR4-2133 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
  • 1 TB 7200 rpm SATA
  • 256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
Dimensions (W x D x H)
35.97 x 24.88 x 1.96 cm
2.16 kg
65 W AC power adapter
3-cell, 55.8 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 45 minutes
Video Playback Battery life
Up to 10 hours
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
