HP Z43 42.5-inch 4K UHD Display Specifications
Product image
Figure : HP Z43 42.5-inch 4K UHD Display
Panel
Specification
Display panel type
In-Plane Switching (IPS)
Display size (diagonal)
42.5 inches
Panel bit depth
True 10-bit
Panel active area (W x H)
941.07 x 529.34 (37.05 x 20.84 in)
Aspect ratio
16:9
Native resolution
3840 × 2160 at 60 Hz
DisplayPort 1.2 or HDMI 2.0 required to drive panel at its native resolution.
Viewing angle (typical)
Up to 178° horizontal (10:1 minimum contrast ratio)
Up to 178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
350 cd/m2
Contrast ratio (typical)
Static
1,000:1
Dynamic
5,000,000:1
Response time (typical)
5 ms (Gray to Gray)
Product default is 8 ms response time and can be adjusted to as low as 5 ms in the display menu. See user guide for more information.
Pixel pitch
0.2451 x 0.2451 mm
Pixels per inch (PPI)
104
Default color temperature
Standard (10000 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut
72% NTSC
96% sRGB
Zero Bright Dot Warranty
Yes
Low blue light capable
Yes
Anti-glare
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu
Next active input
Viewing modes
Power
User programmable modes
20
User-assignable function buttons
3 (with 9 options)
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Traditional Chinese, and Simplified Chinese)
On-Screen Display (OSD) user controls
Luminance, Color Control, Input Control, Image Control, PIP Control, Power Control, Menu Control, Management, Language, and Information
Signal interface/performance
Specification
Maximum resolution
Recommended resolution
Preset VESA graphic modes/supported resolutions
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
720 x 480 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
2560 x 1440 at 60 Hz
3840 x 2160 at 30 Hz
Vertical scan range
47 to 63 Hz
Horizontal scan range
121.8 to 140 kHz
Pixel clock (maximum)
78 MHz
Video/other inputs/cables
Specification
Connector types
(1) DisplayPort (DP) 1.2
(1) Mini DisplayPort (DP) 1.2
(1) HDMI 2.0
HDCP 2.2 supported for HDMI and DisplayPort (DP).
(1) USB 3.1, Gen1
Audio
(1) Analog output
USB hub
(5) USB 3.0
(4) Downstream and (1) Upstream
(3) Fast charging USB ports
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +10° vertical
Swivel
20°( +/- 10°)
4-Way comfort adjust
Adjustable height, tilt, swivel, and pivot
VESA mounting
200 mm (7.87 in) and 100 mm (3.94 in) with integrated mount or bracket
Color
Black Pearl
Monitor bezel and stand
Security lock-ready
Yes
Detachable base
Yes
Power
Specification
Power supply
Internal
Input power
100 to 240 VAC at 50/60 Hz
Maximum power
205 W
Typical power
95 W
Energy aving/standby mode
0.5 W
Power cable length
1.9 m (6.2 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (highest setting)
97.20 x 23.98 x 61.90 cm (38.27 x 9.44 x 24.37 in)
Unpacked without stand (head only)
97.20 x 12.27 x 56.59 cm (38.27 x 4.83 x 22.28 in)
Packaged
111.99 x 70.00 x 35.99 cm (44.09 x 27.56 x 14.17 in)
Unpacked
16.95 kg (37.37 lb)
Packed
23.47 kg (51.74 lb)
Head only
12.45 kg (27.45 lb)
What's in the box?
Specification
Monitor and accessories
AC Power cord
DisplayPort (DP) 1.2 cable
USB-C to USB Type-A cable
Documentation
CD, documentation
HP Display Assistant (with CD)
Environmental
Specification
Temperature
Operating
5°C to 35°C (41°F to 95°F)
Non-operating
–20°C to 60°C (-4°F to 140°F)
Humidity
Operating
20% to 80% (relative Humidity non-condensing)
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlights
Yes
Low halogen
Yes (except cables)
Eco-label certifications & declarations
Microsoft WHQL Certification (Windows 7 and 10)
CE
CB
KC
KCC
PSB
ICE
TUV-S
ISO 9241-307
EAC
UL
PSB
ISC
CCC
CEL
CECP
SEPA
Edge
ISC
VCCI
FCC
BSMI
WEEE
