HP ENVY - 17-ae151nr Product Specifications
1KT20UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® MX150 (4 GB GDDR5 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
DVD-Writer
17.3" diagonal 4K IPS anti-glare WLED-backlit (3840 x 2160)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
41.6 x 28.3 x 2.33 cm
2.9 kg
90 W AC power adapter
3-cell, 55.8 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 30 minutes
Video Playback Battery life
Up to 6 hours and 45 minutes
Bang & Olufsen, dual speakers
HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Pre-installed software
Netflix; CyberLink Power Media Player
