HP Z4 G4 Workstation Specifications
Product image
Feature
Preinstalled
Windows 10 Pro 64 for Workstations (only for Xeon W configurations)
Windows 10 Pro 64 (only for Core X configurations)
Windows 10 Pro High End (only for Core X configurations)
Windows 10 Pro (only for Core X configurations)
Windows 7 64 (downgrade available by request from HP Support; only for Xeon W configurations)
Windows 10 is preinstalled. Only one version of the Windows software can be used at a time. Switching between versions requires uninstalling one version and installing the other version. Back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.
HP Linux Ready
Includes the drivers for 64-bit OS versions of Red Hat Enterprise Linux (RHEL) 6 and 7, SUSE Linux Enterprise Desktop 11 and Ubuntu 14.04.
Red Hat Enterprise Linux Desktop Workstation
Paper license with 1-year support and no preinstalled OS. This second OS must be ordered with the HP Linux Installer Kit as the first OS.
Supported
Red Hat Enterprise Linux Desktop 7.4
SUSE Linux Enterprise Desktop 12 SP3
Ubuntu 16.04.3 LTS
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Intel Xeon W-2195 processor
2.3 GHz
24.75 MB cache and 18 cores
Up to 4.3 GHz with Intel Turbo Boost Technology
Supports DDR4 memory up to 2666 MT/s data rate
140 W
Supports Intel vPro technology
Intel Xeon W-2175 processor
2.5 GHz
19.25 MB cache and 14 cores
140 W
Intel Xeon W-2155 processor
3.3 GHz
13.75 MB cache and 10 cores
Up to 4.0 GHz with Intel Turbo Boost Technology
140 W
Intel Xeon W-2145 processor
3.7 GHz
11 MB cache and 8 cores
Up to 4.5 GHz with Intel Turbo Boost Technology
140 W
Intel Xeon W-2135 processor
3.7 GHz
8.25 MB cache and 6 cores
140 W
Intel Xeon W-2133 processor
3.6 GHz
Up to 3.9 GHz with Intel Turbo Boost Technology
140 W
Intel Xeon W-2125 processor
4.0 GHz
8.25 MB cache and 4 cores
120 W
Intel Xeon W-2123 processor
3.6 GHz
120 W
Intel Xeon W-2104 processor
3.2 GHz
Supports DDR4 memory up to 2400 MT/s data rate
120 W
Intel Xeon W-2102 processor
2.9 GHz
120 W
Intel Core i9-9980XE processor
3.0 GHz
165 W
Intel Core i9-9920X processor
3.5 GHz
19.25 MB cache and 12 cores
165 W
Intel Core i9-9820X processor
3.3 GHz
16.5 MB cache and 10 cores
Up to 4.2 GHz with Intel Turbo Boost Technology
165 W
Intel Core i9-9800X processor
3.8 GHz
16.5 MB cache and 8 cores
165 W
Intel Core i9-7980XE processor
2.6 GHz
165 W
Intel Core i9-7960X processor
2.8 GHz
22 MB cache and 16 cores
165 W
Intel Core i9-7940X processor
3.1 GHz
165 W
Intel Core i9-7920X processor
2.9 GHz
16.5 MB cache and 12 cores
140 W
Intel Core i9-7900X processor
3.3 GHz
140 W
Intel Core i9-7820X processor
3.6 GHz
140 W
Intel Core i9-7800X processor
3.5 GHz
140 W
Intel C422 Chipset (Intel Xeon W Processors)
Intel X299 Chipset (Intel Core X-series Processors)
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Feature
Entry 3D (two graphics card supported)
NVIDIA Quadro P400 2GB Graphics
NVIDIA Quadro P620 2GB Graphics
Dual graphics configuration requires the 750 W chassis or 1000 W chassis.
Mid-range 3D (two graphics card supported)
NVIDIA Quadro P1000 4GB Graphics (first GFX)
NVIDIA Quadro P2000 5GB Graphics (first GFX)
AMD Radeon Pro WX 3100 4GB Graphics
AMD Radeon Pro WX 3200 4GB Graphics
AMD Radeon Pro WX 4100 4GB Graphics
Dual graphics configuration requires the requires the 750 W or 1000 W chassis and the HP Z4 G4 Fan and Front Card Guide Kit, which is available both CTO and AMO.
High End 3D (two graphics card supported)
NVIDIA Quadro P4000 8GB Graphics
Single graphics configuration requires the HP Z4 G4 Fan and Front Card Guide Kit, which is available both CTO and AMO.
Single graphics configuration requires the 750 W chassis or 1000 W chassis.
Dual graphics configuration requires the 1000W chassis.
NVIDIA Quadro RTX 4000 8GB Graphics
AMD Radeon Pro WX 7100 8GB Graphics
Ultra High End 3D (single and dual graphics card support)
NVIDIA Quadro GP100 16GB Graphics
NVIDIA Quadro GV100 32GB Graphics
NVIDIA Quadro P5000 16GB Graphics
NVIDIA Quadro P6000 24GB Graphics
NVIDIA Quadro RTX 5000 16GB Graphics
NVIDIA Quadro RTX 6000 24GB Graphics
NVIDIA Quadro RTX 8000 48GB Graphics
AMD Radeon Pro WX 9100 16GB Graphics (single graphics card supported)
NVIDIA Quadro Sync II
Graphics card connectors
NVIDIA SLI 2-slot Graphics Connector
Quadro RTX NVLink 2-slot Bridge (RTX 5000)
Quadro RTX NVLink High-Bandwidth 2-slot Bridge (RTX 6000 and 8000)
Graphics cable adapters
HP DisplayPort to HDMI Adapter
HP DisplayPort to Dual Link DVI Adapter
HP DisplayPort to DVI-D Adapter
HP DisplayPort to DVI-D Adapter (2-pack)
HP DisplayPort to DVI-D Adapter (4-pack)
HP DisplayPort to DVI-D Adapter (6-pack)
HP Single miniDP-to-DP Adapter Cable
HP Single miniDP-to-DP Adapter Cable (2-pack)
HP Single miniDP-to-DP Adapter Cable (4-pack)
HP Single miniDP-to-DP Adapter Cable (8-pack)
Displays
Feature
Displays
HP Z Display Z22n G2
HP Z Display Z23n G2
HP Z Display Z24i G2
HP Z Display Z24n G2
HP Z Display Z24nf G2
HP Z Display Z27n G2
HP Z27s 27-inch IPS UHD Display (4K display)
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Screen size is measured diagonally. All monitors are supported by all operating systems available from HP.
Memory
Specification
DDR4-2666 registered DIMMs
ECC Registered DIMMs
HP 8GB (8 GB x 1) DDR4-2666 ECC Reg RAM
16 GB (8 GB x 2) DDR4-2666 ECC Reg RAM
24 GB (8 GB x 3) DDR4-2666 ECC Reg RAM
32 GB (8 GB x 4) DDR4-2666 ECC Reg RAM
64 GB (8 GB x 8) DDR4-2666 ECC Reg RAM
16 GB (16 GB x 1) DDR4-2666 ECC Reg RAM
32 GB (16 GB x 2) DDR4-2666 ECC Reg RAM
64 GB (16 GB x 4) DDR4-2666 ECC Reg RAM
128 GB (16 GB x 8) DDR4-2666 ECC Reg RAM
32 GB (32 GB x 1) DDR4-2666 ECC Reg RAM
64 GB (32 GB x 2) DDR4-2666 ECC Reg RAM
128 GB (32 GB x 4) DDR4-2666 ECC Reg RAM
256 GB (32 GB x 8) DDR4-2666 ECC Reg RAM
non-ECC
HP 8GB (8 GB x 1) DDR4-2666 non-ECC Reg RAM
HP 16GB (8 GB x 2) DDR4-2666 non-ECC Reg RAM
HP 32GB (8 GB x 4) DDR4-2666 non-ECC Reg RAM
HP 16GB (16 GB x 1) DDR4-2666 non-ECC Reg RAM
HP 32GB (16 GB x 2) DDR4-2666 non-ECC Reg RAM
HP 64GB (16 GB x 4) DDR4-2666 non-ECC Reg RAM
HP 128GB (16 GB x 8) DDR4-2666 non-ECC Reg RAM
Only DDR4 DIMMs are supported.
Memory configurations using 32GB DIMMs require the HP Z4 Memory Cooling Solution, which is available both CTO and AMO.
Maximum
Supports up to 256 GB with Xeon W configurations
Supports up to 128 GB with Core X configurations
Maximum memory capacities assume 64-bit operating systems such as Windows 10 Pro 64-bit, Windows 7 Professional 64-bit.
For systems installed with Windows 7 (Ultimate, Enterprise or Pro), the maximum accessible system memory is 192 GB.
The processor supports up to 4 channels of DDR4 memory. To realize full performance at least one DIMM must be inserted into each channel. The CPUs determine the speed at which the memory is clocked. If an 2400 MT/s capable CPU is used in the system, the maximum speed the memory runs at is 2400 MT/s, regardless of the specified speed of the memory.
Memory configurations using 32 GB DIMMs require the HP Z4 Memory Cooling Solution, which is available both as CTO and AMO.
Storage and drives
Feature
Serial Attached SCSI (SAS) Hard drive
HP 300GB 15K SAS SFF Hard Drive (controller add-in card required)
Only available on Xeon W configurations.
SATA Hard Disk Drive (HDD)
HP 500GB SATA 6Gb/s 7200 Hard Drive
HP 500GB 7200rpm SATA SFF SED Hard Drive
HP 1TB SATA 6Gb/s 7200 Hard Drive
HP 1TB Enterprise SATA 7200 HDD
HP 2TB SATA 6Gb/s 7200 Hard Drive
HP 4TB SATA 7200 Hard Drive
HP 6TB Enterprise SATA 7200 HDD
Up to (4) 8.89 cm (3.5 in) 7200 rpm SATA drives.
500 GB, 1.0, 2.0, 4.0 TB.
16 TB maximum total.
SATA Solid State Drives (SSD)
HP 256GB SATA SSD
HP 512GB SATA SSD
HP 1TB SATA SSD
HP 2TB SATA SSD
HP 256GB SATA SED Opal2 Solid State Drive
HP 512GB SATA SED Opal2 Solid State Drive
HP Enterprise Class 240GB SATA SSD
HP Enterprise Class 480GB SATA SSD
PCIe Solid State Drives (SSD)
HP Z Turbo Drive 256GB MLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 512GB MLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 1TB MLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 256GB TLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 512GB TLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 1TB TLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 2TB TLC (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 256GB SED (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive 512GB SED (Z4/Z6 G4) SSD Kit
HP Z Turbo Drive Quad Pro
HP Z Turbo Drive Quad Pro 2x256GB PCIe TLC SSD
HP Z Turbo Drive Quad Pro 2x512GB PCIe TLC SSD
HP Z Turbo Drive Quad Pro 2x1TB PCIe TLC SSD
HP Z Turbo Drive Quad Pro 2x2TB PCIe TLC SSD
Dual M.2 SSD modules plus the carrier.
HP Z Turbo Drive Quad Pro 256GB TLC SSD module
HP Z Turbo Drive Quad Pro 512GB TLC SSD module
HP Z Turbo Drive Quad Pro 1TB TLC SSD module
HP Z Turbo Drive Quad Pro 2TB TLC SSD module
Z Turbo Drive Quad Pro modules require the Z4 G4 Fan and Front Card Kit, available as CTO.
Z Turbo Drive Quad Pro modules are not supported on Core i7-X configurations.
M.2 SSD module only that are designed to be installed into the Quad Pro carrier.
HP Z Turbo Drive Dual Pro
HP Z Turbo Drive Dual Pro 256GB TLC SSD
HP Z Turbo Drive Dual Pro 512GB TLC SSD
HP Z Turbo Drive Dual Pro 1TB TLC SSD
HP Z Turbo Drive Dual Pro 2TB TLC SSD
Intel 905p Series SSD (Opatane SSD)
Intel Optane SSD 905p 280GB AIC
Intel Optane SSD 905p 480GB AIC
Intel Optane SSD 905P 380GB M.2 PCIe Dual
Intel Optane SSD 905P 2x380GB M.2 PCIe Quad
Intel Optane SSD 905P 380GB M.2 SSD Module
Z Turbo Drive Quad Pro is not supported on Core i7-X configurations.
Intel Virtual RAID on CPU (Intel VROC) for NVMe
Intel VROC NVMe SSD Standard Controller Module
Xeon processor required
Enables RAID 0, 1 and 1 and 0
Enables RAID 0, 1 & 10 plus RAID 5 with write hole closure options
Hard drive controllers
MicroSemi 2100-4i4e SAS Controller (Smart Host Bus Adapter)
HP Slim tray optical drives
HP 9.5mm Slim Blu Ray Disc Writer
HP 9.5mm Slim DVD ROM
HP 9.5mm Slim DVD Writer
HP HH DVD Writer (16X RW DVD-R)
Installing an optical drive into Z4 G4 requires a 13.33 cm (5.25 in) external bay adapter.
NVMe Frame/carrier
HP QX310 Removable NVMe Frame/xarrier w/PCIe card
Card reader
HP SD 4 Card reader
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Ports/slots/bays
Input/output ports
Front I/O (base)
(4) USB 3.1 Gen 1 Type-A (1 charging)
(1) Headset audio port
Front I/O (optional)
(1) Optional media card reader
Front I/O (optional premium)
(2) USB 3.1 Gen 1 Type-A connector (1 charging)
(2) USB 3.1 Gen 2 Type-C connector
(1) Headset headset
(1) Power button with power/fault LED
(1) Drive activity LED
Internal I/O
(1) USB 3.1 Gen 1 (aka USB 3.0) single-port header
(1) USB 2.0 single-port header
(1) USB 2.0 dual-port header
Rear I/O (for Xeon W configurations)
(6) USB 3.1 Gen 1 (aka USB 3.0) Type-A ports
(2) 1 Gbe LAN ports (1x supporting Intel AMT)
Intel AMT is not available on Intel Core X configurations.
Rear I/O (for Core X configurations)
(5) USB 3.1 Gen 1 (aka USB 3.0) Type-A ports
(1) 1 Gbe LAN ports (1x supporting Intel AMT)
Rear I/O (common)
(1) Audio line-out
(1) Audi line-in (line-in can be retasked as microphone)
(1) PS/2 mouse
(1) PS/2 keyboard
(1) Rear power button
(1) serial port (cable up to rear bulkhead)
Slot 0 (mechanical only)
Only for rear bulkhead mounting
Slot 1
PCI Express Gen 3 x16 (from CPU)
Slot 2
PCI Express Gen 3 x16 (from PCH) with open-ended connector
Slot 3 (for Xeon W)
Slot 3 (for Core i9-X)
Slot 3 (for Core i7-X)
PCI Express Gen 3 x16 (from CPU) mechanical
PCI Express Gen 3 x8 (from CPU) electrical
Slot 4
Slot 5
Slot 5 (for Core i9-X)
Slot 5 (for Core i7-X)
PCI Express Gen 3 x8 (from CPU) mechanical
M.2 Slot 1
M.2 PCIe Gen 3 x4 - CPU up to 80 mm (3.15 in) storage devices
M.2 Slot 2 (for Xeon W)
M.2 Slot 2 (for Core X)
M.2 connector/slot not available
Expansion bays
(2) Internal 8.89 cm (3.5 in) bays
Optional 6.35 cm (2.5 in) adapter available.
(2) External 13.33 cm (5.25 in) bays
(1) 9.5 mm (0.37 in) slim optical disk drive bay
Audio/multimedia
Feature
Audio
Integrated Realtek HD ALC221 Audio
Keyboard and mouse/other hardware
Feature
Keyboards and mouse
HP Wireless Business Slim Keyboard and Mouse
HP PS/2 Slim Business Keyboard
HP USB Slim Business Keyboard
HP USB Premium Keyboard
HP USB SmartCard CCID Keyboard
3Dconnexion CadMouse
HP Optical USB Mouse
HP PS/2 Mouse
HP USB Hardened Mouse
Other hardware
HP Z Premium Front I/O 2xUSB-A 2xUSB-C
HP Z4 G4 Memory Cooling Solution
The HP Z4 G4 Memory Cooling Solution is available to add to any configuration for improved system cooling, but is required for memory configurations using 32 GB DIMMs.
HP Internal USB Port Kit
HP eSATA 2 port PCI Bulkhead Kit
HP Serial Port Adapter
HP Workstation mouse pad
Networking/communication
Feature
Communications
Intel Wi-Fi 6 AX200 & BT PCIe
Windows 7 is NOT supported.
HP i350-T2 PCIe Dual Port Gigabit NIC
Intel i350-T4 PCIe 4-Port Gigabit NIC
Intel Ethernet I210-T1 PCIe x1 Gb NIC
Aquantia NBASE-T 5GbE PCIe NIC
Intel X550-T2 10GbE Dual Port NIC
Intel X710-DA2 10GbE SFP+ Dual Port NIC (Windows 7 is not supported)
Intel 8265 802.11a/b/g/n/ac with Bluetooth PCIe WLAN
HP 10GbE SFP+ SR Transceiver
Software/security
Specification
Sobey video editing software
HP Remote Graphics Software
BIOS
Standard BIOS 32-bit Service Directory Proposal v0.4
PCI Local Bus specification, revision 2.3
PCI Power Management specification, revision 1.1
PCI Firmware specification, revision 3.0, draft .7
PCI Express Base specification, revision 2.0
PCI Express Base specification, revision 3.0
POST Memory Manager specification, version 1.01
ATAPI Removable Media Device BIOS specification version 1.0
WMI support
BIOS Boot spec 1.01+ (disables the ability to boot from removable media on supported devices)
UEFI 2.5
ACPI version 5.0
Enhanced Host Controller Interface for Universal Serial Bus, revision 1.0
LANDesk Management Suite (HP recommended solution)
Microsoft System Center Configuration Manager
HP Client Automation Enterprise
Security
Trusted Computing Group
TPM specification version 2.0
Infineon SLB 9665 (Common Criteria EAL4+ certified)
Remote wakeup/remote shutdown
Memory change alert
Thermal alert
Security cable with Kensington lock (optional)
HP Z4/Z6 Side panel barrel keylock
HP Solenoid Lock/hood Sensor
HP Z4/Z6 Depth Adjustable Fixed Rail Rack Kit
HP Keyed Cable Lock 10 mm
Workstation ISV certifications
Go to the Workstation ISV certifications webpage to see current certifications
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Power supply
Entry (Xeon series)
465 W
90% Efficient wide-ranging, active Power Factor Correction (PFC)
Mid-Range (Xeon series)
750 W
High-End (Xeon and Core i9 series)
1000 W
Includes 4x 6+2-pin graphics power cables
Includes a Front Fan and Card Guide kit to enable support for dual high end graphics solutions
High-End (Core i7 series)
1000 W
Includes 2x 6+2-pin graphics power cables
Buttons
(1) Front power button and LED
Physical specifications
Dimensions (H x W x D)
38.61 x 16.89 x 44.45 cm (15.2 x 6.65 x 17.5 in)
Rack dimensions
4U
Minimum
10.2 kg (22.49 lb)
Typical
11.3 kg (24.91 lb)
Maximum
17.3 kg (38.14 lb)
Exact weights depend upon configuration.
Environmental specifications
Feature
Certifications
US ENERGY STAR (select models only)
Low Halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
US Federal Energy Management Program (FEMP)
China Energy Conservation Program
The ECO declaration (TED)
EPEAT Gold registered where applicable (registration varies by country/region)
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-40° to 60°C (40° to 140°F)
Humidity
Operating
10% to 85% (non-condensing, 35° C maximum wet bulb)
Non-operating
10% to 90% (non-condensing, 35° C maximum wet bulb)
Altitude (unpressurized)
Operating
3,048 m (10000 ft)
Non-operating
9,144 m (30000 ft)
