Samsung Printers - Smart UX Appendix: Apps and Widgets from the App Center
Apps
Easy Launcher: Provides customer-specific look and feel with basic copy, scan, and fax.
Workbook Composer: Automatically exports multiple selected areas.
SmarThru Web Viewer: SmarThru Web Service viewer accesses all admin functions without a PC or network.
Smart Service: Displays error/warning status. Links to related troubleshooting.
Send Anywhere: Simple and easy data share between MFP and other devices.
Smart UX Lib Support: Provides Samsung Smart UX SDK functionality.
Hancom Office: Office Document Editor, MS Office with HWP view, edit, print.
Samsung Mobile Print: Prints or sends fax documents, emails, email attachments, and web pages.
Hancom Office Shared: Includes fonts, templates, dictionary data, and clipart data.
Scan & Send: Scans a document and sends it to multiple destinations.
Hancom Office HWP 2014: Supports editing .hwp documents.
Smart Color Manager: Adjusts the color table and creates a color profile.
Widgets
Toner Gauge: Easy-to-check toner gauge.
Memo: Displays the admin's number or printer info (IP, name) on the home screen.
Account: Easy-to-check user's quota.
Language Selector: Change device language.
Easy launcher
Launcher tool is a perfect example of the new level extensibility only Smart UX can provide.
Workflow
Customized home with branded widgets.
  1. Start the Launcher Tool.
    Figure : Easy launcher
  2. When pressing the home key, users can choose to use the new desktop or the initial TouchWiz desktop.
    Figure : New or old desktop
    1. The launcher tool consists of one main app and three widgets (scan, copy, fax).
      Figure : Scan widget
      Figure : Fax widget
Benefit
  • Creates a customer-specific look and feel.
  • Easy widgets to streamline any basic copy, scan, or fax job.
  • Perfect example of the apps that can be developed for Smart UX to offer a new level extensibility.
SyncThru Web Viewer
Easiest way to access the admin function.
  • Stand-alone SyncThru Web Service: Enables access to all admin functions without a PC or network.
  • One-click access to SyncThru Web Service: IP address and web browser are not required.
  • Before
    • Network is required.
    • IP address must be remembered.
    • Connected PC is required.
      Figure : Before
  • After
    • No network is required.
    • All admin functions are available.
      Figure : After
Send anywhere (app)
Simple and easy data share between the MFP and other devices.
  • Platform independent: Enables access to PC and mobile devices such as Android, iOS, Windows, Linux, and Mac OS.
  • Reinforced security: Uses OTP (one time password) and automatically deletes data within 24 hours.
  • Does not require ID/password: Membership free and no login required.
  • Why Send Anywhere: Most email systems restrict file sizes to 10 MB, but Send Anywhere has no restriction.
File sharing scenario:
    Figure : As is
  1. Use USB, shared folder, or email to share.
    Figure : Newly added
  1. Send file through app > generate OTP > enter OTP at destination.
Hancom Office 2014
Versatile Hancom Office 2014 increases the extensibility to new heights.
Workflow
Editing and printing documents on the printer.
Figure : Hancom Office display
  • Users can open their Word template stored on the printer and easily change the required information, such as, dates or contact details.
  • Users can directly print out the edited document.
  • Hancom Office 2014 is available in the Printing App Center.
Benefit
  • Users can open, print, or edit their MS Office documents directly on the printer.
  • This ability turns the MFP into an independent document hub.
  • Enables users to make ad hoc change or corrections to stored documents without a PC.
Workbook composer
Automatically detects and exports red-marked areas (supports multiple areas), and combines them into one document with selected areas. Touch and drag selection is possible.
Workflow
Crop multiple areas and create one output document to print, save, or share.
    Figure : Workbook example
  1. Select area (red) > scan > convert document
  • Red marker can also be used to mark the selections to crop.
  • Workbook Composer is available for download from the Printing App Center.
Benefit
  • Easily crop different sections, such as from a magazine.
  • Save time and effort performing these tasks without a PC. If necessary, editing can be completed on a PC.
  • Great value addition for the education sector.
Smart service
The Smart Service app enhances service quality and speed.
Workflow
Troubleshoot printers with ease.
  1. When an error occurs, launch Smart Service.
    Figure : Smart service, launch
  2. Videos related to the error are made available.
    Figure : Error videos
  3. View the video for a possible solution.
    Figure : Video solution
  • Smart Service app requires the videos to be uploaded to the MFP.
  • Smart Service is available in the Printing App Center.
Benefit
  • Onsite support: Decrease the time required for troubleshooting by the service engineers.
  • Offers end users the ability to determine whether a service call is necessary, or if the issue can be resolved by following the solution proposed in the videos.
Samsung mobile print (for smart UX)
Optimize the printer resources, such as using the fax function with a mobile print app.
Workflow
Sending a fax from a MFP via Mobile Print.
    Figure : Mobile print
  1. No fax option
  2. Sending fax
  3. Fax option installed
  • Users can take advantage of the fax option installed on another MFP remotely using the Mobile Print app.
  • The Mobile Print app is available from the Printing App Center.
Benefit
  • Provides additional features for the users:
    • Send faxes from the closest MFP, without having the fax option kit installed, through peer MFPs with the fax option installed.
    • Share stored documents by printing them directly to a colleague at another MFP (push printing).
Toner gauge widget
Toner and imaging unit status is visible directly on the MFP's display for easier management of supplies. The widget shows the status of all supplies or limits the status view only to toner.
Figure : Toner gauge widget
Screen memo widget
  • The Screen Memo widget enables users to display information such as the device IP or support details. If might also be used to inform users that new toner has been ordered and is due to be delivered on a certain date.
  • Adding pictures to the memos can make messages more efficient.
  • Memos can also be locked with a PIN to prevent deleting the memo or any unauthorized access to edit the memo.
Figure : Screen memo
Account status viewer
Display each user's account status in one screen.
  • When users logs into the printer, this widget provides information about the user account.
  • The widget displays the following information:
    • Total quote.
    • Remaining amount for copy, print and fax, color usage, and sent-to-xxx.
  • Account information is based on the device-embedded Standard Accounting setting information.
    • Linking with BCPS (SecuThru Lite or Usage Tracker) will be supported in the next updated.
The widget provides the total quote and remaining amount for the logged in user.
Figure : Account status viewer
Language selector
Using the Language Selector is an easy way to change the language directly from the home screen without using the settings menu. Up to four languages can be easily changed.
    Figure : Language options
  1. Choose up to four favorite languages
    Figure : Favorite languages
  1. Change the language using the widget
