HP Pavilion x360 - 15-br080wm Product Specifications
1KT65UA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • Intel® HD Graphics 620
  • Integrated
1 TB 5400 rpm SATA
15.6" diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 headphone/microphone combo
Dimensions (W x D x H)
37.78 x 24.58 x 2.03 cm
2.14 kg
45 W AC power adapter
Battery life mixed usage
Up to 12 hours
Video Playback Battery life
Up to 10 hours and 15 minutes
B&O PLAY; HP Audio Boost; Dual speakers
Pre-installed software
Netflix
What's in the box?
Contents
Stylus pen (natural silver)
