HP Pavilion - 15-cc108tx Product Specifications
2SM17PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
37.8 x 25.21 x 2.25 cm
Starting at 2.02 kg
90 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
Battery life mixed usage
Up to 9 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
