    We are upgrading our website
HP VH27 27-inch Monitor Specifications
Product image
Figure : HP VH27 27-inch Monitor
Panel
Specification
Display panel type
IPS with LED backlight
68.58 cm (27.0 in) widescreen
Panel active area (W x H)
59.79 x 33.63 cm (23.54 x 13.24 in)
Resolution
1920 x 1080 at 60 Hz (Full HD)
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
Brightness
250 cd/m2
Contrast ratio
Static
1,000:1 (typical)
Dynamic Contrast Ration (DCR)
5,000,000:1
Response times
5 ms Gray to Gray
Pixel pitch
0.3114 mm
Pixels Per Inch (PPI)
81.59
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut (typical)
72% (NTSC)
Anti-glare panel
Yes
Flicker free
Yes
Low blue light capable
Yes
Actual performance varies.
User controls
Specification
Buttons or switches
Menu/OK
Information/Minus
Viewing Modes/Plus
Next Active Input/Exit
Power
User-assignable function buttons
3
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Pixel clock
170 MHz (maximum)
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Video inputs/cables
Specification
Connector types
(1) HDMI 1.4
(1) DisplayPort (DP) 1.1
HDCP supported for HDMI and DP.
(1) VGA (with 1.8 m (5.9 ft) cable)
Cables
(1) VGA 1.8 m (5.9 ft) cable
(1) DP 1.8 m (5.9 ft) cable
Ergonomics
Specification
Plug and play
Yes
Detachable stand
Yes
Tilt range
-5° to +23° vertical
Swivel
Yes, 360°
Pivot
Yes, 90°
Height
Yes, 100 mm (3.94 in)
Color
Black
Security lock-ready
Yes
VESA mount
Yes (3.94 in)
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
32 W
Typical power
23 W
Sleep power
0.5 W
Power cable length
1.83 m (6.0 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (lowest setting)
51.99 x 21.79 x 52.53 cm (24.47 x 8.58 x 20.68 in)
Packaged
70.99 x 21.89 x 47.29 cm (27.95 x 8.62 x 18.62 in)
Head only
62.03 x 4.60 x 37.13 cm (24.47 x 1.81 x 14.63 in)
Unpacked
6.1 kg (13.45 lb)
Packaged
8.57 kg (18.89 lb)
Head only
3.98 kg (8.77 lb)
What's in the box?
Specification
Monitor and accessories
Power cable 1.83 m (6.0 ft)
VGA cable 1.8 m (5.9 ft)
Documentation
Warranty card and QSP
HP Display Assistant (with CD)
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-34° to 60°C (-29.2° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase may not be low halogen.
Eco-label certifications & declarations
ENERGY STAR 7.0
EPEAT Gold (registration varies by country/region)
Microsoft WHQL certification (Windows 7, 8, and 10 RS2)
TCO certified
CB
cTUVus
FCC
ICES
TCO
