Document ID: c05811690
Version: 1
Advisory: HP Engage One 2D Barcode Scanner - Cannot Configure COM Mode Using Barcode in Programming Reference Guide
Release date : 24-Oct-2017
Last updated : 01-Aug-2018
DESCRIPTION
Unable to program COM mode on the barcode scanner using configuration barcode on page 2-2 of the HP ElitePOS 2D Barcode Scanner Programming Reference Guide (first edition: August 2017, 937402-001):
After scanning the barcode, the unit emits a beep but nothing happens in Device Manager (COM port does not appear).
SCOPE
Barcode scanners:
  • HP Engage One 2D Barcode Scanner
RESOLUTION
Use the following configuration barcode to set the HP Engage One 2D Barcode Scanner interface to COM mode.
USB COM
Hardware platforms affected : HP Engage One 2D Barcode Scanner
Support Communication Cross Reference ID : IA05811690
