HP EliteDisplay E273q 27-inch Monitor Specifications
Product description
Figure : HP EliteDisplay E273q 27-inch Monitor
Panel
Specification
Display panel type
IPS Micro edge, LED backlight
Display size (diagonal)
27 inches
68.58 cm (27.0 in)
Panel active area (W x H)
59.6 x 33.5 cm (23.46 × 13.18 in)
Aspect ratio
16:9
Resolution
2560 x 1440 at 60 Hz (digital inputs only USB Type-C, DisplayPort, and HDMI)
The video card of the connected PC must be capable of supporting 2560 x 1440 at 60 Hz.
Viewing angle (typical)
Up to 178° horizontal
Up to 178° vertical
10:1 minimum contrast ratio
Brightness (typical)
350 cd/m2
Contrast ratio
Static
1,000:1 (typical)
Dynamic
5,000,000:1 (typical)
Response time
5 ms
Product default is 14 ms response time and can be adjusted to as low as 5 ms in the display menu. See user guide for more information.
Pixel pitch
0.2331 mm
Pixels per inch (PPI)
108.8
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color support
Up to 16.7 million colors with the use of FRC technology (8-bit)
Color gamut
99.6% sRGB
Surface hardness
3H
Flicker free
Yes
Low blue light capable
Yes
Anti-glare
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu
Information/Auto-Adjust (assignable)
Viewing Mode (assignable)
Next Active Input (assignable)
User-assignable function buttons
20
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Traditional Chinese, and Simplified Chinese)
On-Screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Maximum resolution
Preset VESA graphic modes (noninterlaced)/supported resolutions
640 x 480 at 60Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
2560 x 1400 at 60 Hz (digital inputs only USB Type C, DisplayPort, HDMI)
Vertical scan range
50 to 60 Hz (VGA, DP, HDMI, and USB-C)
Horizontal scan range
30 to 90 kHz (VGA, DP, HDMI, and USB-C)
Pixel clock (maximum)
200 MHz (VGA)
250 MHz (DP, HDMI, and USB-C)
Video/other inputs/cables
Specification
Connector types
(1) DisplayPort (DP) 1.2
(1) HDMI 1.4
HDCP supported for HDMI, DisplayPort, USB Type-C.
(1) VGA
USB ports
(2) USB 3.0 (downstream)
(1) USB Type-C (upstream, power delivery up to 15 W (5 V, 3 A))
Maximum transaction speed of USB Type-C port is 5 GB/s.
Cables included
Video cables
(1) HDMI 1.8 m (5.9 ft)
(1) DisplayPort 1.8 m (5.9 ft)
USB cable
(1) USB 3.1 Type-C to Type-A, 5 V/3 A cable 1.8 m (5.9 ft)
Ergonomics
Specification
Plug and play
Yes
Tilt range
-5° to +22° vertical
Swivel
45°L to 45°R
Pivot rotation
Yes (90° clockwise and counter-clockwise)
Height adjustment range
0 to 150 mm
4-Way comfort adjust
Adjustable height, tilt, swivel, and pivot
VESA mounting
100 mm (3.94 in) with integrated mount
Cable management
Integrated
Effortless routing of cables through the stand
Color
Silver
Facing bezel, side frame, column stand, and foot
Black
Rear cover and stand center trim
Security lock-ready
Yes
Power
Specification
Power supply
Internal
Input power
100 to 240 VAC at 50/60 Hz
Maximum power
75 W
Typical power
47 W
Sleep power
0.5 W
Power cable length
1.9 m (6.2 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand (highest setting)
61.26 x 21.40 x 52.29 cm (24.1 x 8.4 x 20.6 in)
Unpacked without stand (head only)
61.26 x 4.93 x 36.4 cm (24.1 x 1.9 x 14.3 in)
Packaged
70.7 x 28.2 x 44.4 cm (27.8 x 11.1 x 17.5 in)
Unpacked
7.4 kg (16.3 lb)
Packed
10.6 kg (23.4 lb)
Head only
4.6 kg (10.1 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord
HDMI cable
DisplayPort (DP) 1.2 cable
Documentation
CD, documentation
HP Display Assistant (with CD)
Environmental
Specification
Temperature
Operating
5°C to 35°C (41°F to 95°F)
Non-operating
–20°C to 60°C (-4°F to 140°F)
Humidity
Operating
20% to 80% (relative Humidity non-condensing)
Non-operating
5% to 95% (38.7°C maximum wet-bulb)
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlights
Yes
Low halogen
Yes (except cables)
Eco-label certifications & declarations
ENERGY STAR
EPEAT (registration varies by country/region)
BSMI
CB
CCC
CE
CEL
CECP
FCC
ICE
ISC
ISO 9241-307
PSB
TUV-S
VCCI
WEEE
RCM
TUV-GS
EAC
Vietnam MEPS
Australian-New Zealand MEPS
SmartWay Transport Partnership (NA only)
Microsoft WHQL Certification (Windows 7 and 10)
cTUVus
Mexico CoC
MSIP
