OMEN by HP 15-ax253tx Laptop PC Product Specifications
2YD42PA
Intel® Core™ i5-7300HQ (2.5 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
Video graphics
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1 Gen 1, 1 RJ-45
Dimensions (W x D x H)
38.2 x 25.3 x 2.45 cm
Starting at 2.1 kg
150 W AC power adapter
4-cell, 63.3 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 30 minutes
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
