HP LaserJet, HP PageWide - Setup the printer to scan in macOS X
To use Apple’s Image Capture, the HP Easy Scan app, or other scan methods, the HP printer must be configured to meet the eSCL protocol needed to scan using an AirPrint or network connection.
Step one: Get the latest scan software
To scan using HP Easy Scan, or to get the latest software needed for scanning, download and install the latest HP Easy Start utility. The HP Easy Start utility includes fax and/or scan drivers, and advanced HP features (HP Easy Scan, HP Easy Color, custom paper sizes, job storage, folder or stapler finishing, watermark, etc.). For EasyStart compatible printers, go to Printers compatible with macOS High Sierra 10.13, Sierra 10.12, and El Capitan 10.11.
HP Easy Scan is compatible with El Capitan, Sierra, and High Sierra, and is the recommended scanning application for an HP LaserJet Pro MFP.
  • If you have previously installed the printer using HP Easy Start, launch the HP Easy Start app from the dock and follow the onscreen instructions.
  • For first-time printer installs, follow these steps:
    1. Download the HP Easy Start utility.
    2. Launch the app, select the printer, and then let the utility automatically install the driver(s) and add the print queue.
Step two: Enable eSCL to allow scanning to the HP printer
To enable the printer to work with Image Capture when scanning with a macOS X, follow these steps:
  1. Open the printer’s Embedded Web Server (EWS).
    • Open a Web browser, and in the address field, type the printer IP address in the url field exactly as it appears on the Configuration Page and then press Enter.
  2. Select the Networking tab.
  3. Select either Advanced or Other Settings from the left menu pane (depending on the printer model).
  4. Select either the eSCL, Secure eSCL, WebScan, or Secure WebScan option (depending on the printer model and firmware version).
  5. Select Apply.
  6. Select the Security tab, and if available, select Enable Remote User Auto Capture and Webscan Auto Capture Jobs.
  7. Select Apply and then select OK.
If the printer supports scanning with Image Capture, you can also scan from Apple's Preview or the Print & Scan window.
For information on available scan methods, go to HP LaserJet, HP PageWide - Scan in macOS X.
