HP Spectre x360 - 15-bl152nr Product Specifications
Z4Z39UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
  • NVIDIA® GeForce® MX150 (2 GB GDDR5 dedicated)
  • Discrete
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal 4K IPS eDP micro-edge BrightView WLED-backlit (3840 x 2160)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
Dimensions (W x D x H)
35.6 x 25.1 x 1.79 cm
2 kg
90 W AC power adapter
6-cell, 79.2 Wh Li-ion
Bang & Olufsen, dual speakers
HP Sure Connect; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant
Pre-installed software
Netflix
What's in the box?
Contents
Stylus pen (dark ash silver)
