HP ENVY - 15-as120nr Product Specifications
X7V47UA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
12 GB DDR4-2133 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • Intel® HD Graphics 620 (up to 6.06 GB)
  • Integrated
256 GB M.2 SSD
15.6" diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data up to 5 Gb/s); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
Dimensions (W x D x H)
38 x 25.5 x 1.79 cm
2.13 kg
45 W AC power adapter
3-cell, 52 Wh Li-ion
Bang & Olufsen, dual speakers
HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Pre-installed software
Netflix
