Samsung ProXpress MFP SL-C4060, SL-C4062 - Supplies, Accessories, and Maintenance Parts
Available supplies
This document is for learning about available supplies to order and install for the printer.
Depending on the options and job mode used, the toner cartridge’s life span might differ.
When purchasing new toner cartridges or other supplies, they must be purchased in the same country as the printer being used. Otherwise, new toner cartridges or other supplies will be incompatible with the printer due to different configurations of toner cartridges and other supplies per the specific country conditions.
Type
Average yield
Model
Part name
Toner cartridgea
  • Average continuous black cartridge yield: Approx. 15,000 standard pages
  • Average continuous color cartridge yield: Approx. 10,000 standard pages(Yellow, Magenta/Cyan)
Samsung C4060
  • CLT-K603L: Black
  • CLT-M603L: Magenta
  • CLT-Y603L: Yellow
  • CLT-C603L: Cyan
Samsung C4062b
  • CLT-K604Lb:Black
  • CLT-M604Lb:Magenta
  • CLT-Y604Lb:Yellow
  • CLT-C604Lb:Cyan
Waste toner container
Approx. 20,000 black pages or 5,000 color pages
CLT-W506
a. Declared yield value in accordance with ISO/IEC 19798. The number of pages may be affected by operating environment, printing interval, graphics, media type and media size.
b.The toner cartridge is available only for C4062 series bought in the United States and Canada.
Available accessories
Accessories can be purchased and installed to enhance the printer’s performance and capacity.
If the installation guide for the optional accessory does not include information about how to install the accessory in the printer model, then search for the printer model for information about how to install the accessory.
Accessory
Function
Part name
Stand
Using the stand with its wheels, easily moves the machine.
When using the optional Stand, you must install the foot as shown in the Optional Stand Installation Guide. Otherwise, the machine could fall over if on an incline and cause bodily harm.
SL-DSK003S
Optional trays (Tray 2, Tray 3, Tray 4)
To reduce frequent paper supply problems, attach an additional 550a sheet trays.
SL-SCF3001
Memory
This module lets you extend the machine's memory capacity.
SL-MEM0020
Wi-Fi/NFC kit
This kit allows the machine to be used as a Wi-Fi and NFC (Near Field Communication) machine.
SL-NWE001X
Wi-Fi/NFC/BLE kit
This kit lets you use your machine as a Wi-Fi, NFC (Near Field Communication) and BLE (Bluetooth Low Energy) machine.
SL-NWE002X
a. Plain paper 75 g/m.2 (20 lbs bond).
Available maintenance parts
Replace the maintenance parts at specific intervals to keep the printer in the best condition, and to avoid print quality and paper feeding problems resulting from the worn-out parts. Maintenance parts are mostly rollers, belts and pads. However, the replacement period and parts might differ depending on the model. Replacing maintenance parts can be performed only by an authorized service provider, dealer, or the retailer where the printer was purchased.
To purchase maintenance parts, contact the retailer where the printer was purchased. The replacement period for the maintenance parts is informed by the Samsung Printer Status program. Or on the UI (User Interface) if the printer supports a display screen. The replacement period varies based on the application software, paper type, paper size, and job complexity.
