HP Z238 Microtower Workstation - Overview
Product description
Figure : HP Z238 Microtower Workstation
Physical specifications
Dimensions (H x W x D)
355.6 x 165.1 x 358.14 mm (14.0 x 6.5 x 14.1 in)
Minimum
6.42 kg (14.15 lb)
Typical
6.99 kg (15.41 lb)
Maximum
7.90 kg (17.41 lb)
As configured with (2) 8.89 cm (3.5 in) Hard drive, (1) Optical drive, (2) DIMMs, and (1) NVIDIA Quadro K620 graphics card.
Exact weights depend upon configuration.
