Samsung ProXpress SL-M3820, SL-M4020 - Useful Menu Settings
Accessing the menu
  1. Press (Menu) button on the control panel.
  2. Press the arrows until the needed menu item appears, then press OK.
  3. If the setting item has sub menus, repeat Step 2.
  4. Press OK to save the selection.
  5. Press (Cancel) to return to the ready mode.
Items
Options
Menu Map
Configuration
Demo Page
Supplies Information
Usage Counter
Accounta
PCL Font
PS Font
EPSON Font
KSC5843 Fontb
KSC5895 Fontb
KSSM Fontb
Layout
Orientation
Portrait, Landscape
Margin
Common Margin, MP Tray, Tray X, Emulation Margin
Duplex
Off, Long Edge, Short Edge
Paper
Copies
MP Tray
Paper Size, Paper Type
Tray X
Paper Source
Tray 1, Tray 2c, MP Tray, Auto
Graphic
Resolution
Standard, High Resolution
Clear Text
Off, Minimum, Normal, Maximum
Auto CR
System Setup
Date & Timed
Clock Moded
Language
Default Paper
A4, Letter
Power Save
Wakeup Event
Job Timeout
Altitude Adjustment
Normal, High 1, High 2, High 3, High 4
Auto Continue
Auto Tray Switch
Paper Substitution
Tray Protection
Skip Blank Pages
Maintenance
CLR Empty Messagee, Supplies Life, Image Manager, TonerLow Alert, ImgU.Low Alertf, RAM Disk
Toner Save
Eco Settings
Auto Power Off
a. This is used and only available when Job Accounting is enabled from the SyncThru™ Web Admin Service.
b. This option might not be available depending on the country/region.
c. This option only appears when an optional tray is installed.
d. M382xDW models only.
e. This option only appears when small amount of toner is left in the cartridge.
f. M3325, M3825, M4025 series only.
Items
Options
Emulation
Emulation Type
Setup
Network
TCP/IP (IPv4)
DHCP, BOOTP, Static
TCP/IP (IPv6)
IPv6 Protocol, DHCPv6 Config
Ethernet
Ethernet Port, Ethernet Speed
802.1x
Wi-Fib
Wi-Fi On/Off, Wi-Fi Settings, WPS, Wi-Fi Direct, Wi-Fi Signal, CLR Wi-Fi Settings
Protocol Manager
HTTP, WINS, SNMPv1/v2, UPnP (SSDP), mDNS, SetIP, SLP
Network Configuration
Clear Setting
Job Managementa
Active Job
Secured Job
Stored Job
Print, Delete
Filing Policy
Change Name, Overwrite
a. This option is available when the optional memory installed or RAM Disk is checked.
b. M382xDW models only.
Before reading the following sections
This section explains all the features available for this series' models to help users easily understand the features. Users can check the features available for each model in the Basic Guide, see Menu overview. The following are tips for using the following sections:
  • The control panel provides access to various menus to set up the printer or use the printer’s functions. These menus can be accessed by pressing (Menu).
  • Some menus might not appear on the display depending on options or models. If so, it is not applicable to the printer.
  • For models that do not have the (Menu) on the control panel, this feature is not applicable. See Control panel overview.
  • Some menu names might differ from the printer depending on its options or model.
