HP Z38c 37.5-in Curved Display - Specifications
Panel
Specification
Type
37.5-in IPS, LED backlit
95.29 cm (37.52 in) widescreen
Panel active area (W x H)
87.97 x 36.65 cm (34.63 x 14.43 in)
Micro-edge bezel
Yes
3-sided
Curved panel
Yes
2300r
Hardness
3H
Resolution
3840 x 1600 at 60 Hz
Aspect ratio
21:9
Viewing angle (typical CR>10)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
300 cd/m2
Contrast ratio (typical)
1,000:1
Dynamic contrast ratio (typical)
5,000,000:1
Response times (typical)
5 ms Gray-to-gray
Product default response time is 14 ms and can be adjusted to as low as 5 ms in the display menu. See user guide for more information.
Pixel pitch
0.22908 (H) x 0.22908 (W) mm
Pixels Per Inch (PPI)
100.93
Default color temperature
6504 K (D65)
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut (typical)
98% of sRGB
Panel bit depth
10-bit (up to 1.07 billion colors)
8-bit and 2-bit with the use of FRC technology.
Anti-glare panel
Yes
Flicker-free
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu, Minus ("-")/Color Control, Plus ("+") /Viewing Modes, Back/Next Active Input, and Power
User Programmable Modes
Yes, 10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu control, Management, Language, and Information
Signal interface/performance
Specification
Native resolution
3840 × 1600 at 60 Hz
Recommended resolution
Preset VESA graphic modes/supported resolutions (non-interlaced)
640 × 480 at 60 Hz
720 × 400 at 70 Hz
800 x 600 at 60 Hz
720 x 480 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
1920 x 1200 at 60 Hz
1920 x 1600 at 60 Hz
2560 x 1080 at 60 Hz
2560 x 1600 at 60 Hz
3840 x 1600 at 30 Hz
Maximum pixel clock speed
600 MHz
Vertical frequency
24-76 Hz
Horizontal frequency
27-130 kHz
Video/audio/other inputs
Specification
Plug and play
Yes
Input connectors
(1) DisplayPort 1.2
(1) HDMI 2.0
(1) USB Type-C
HDCP support, all video inputs.
Audio
(1) Audio out (analog)
USB port specifications
USB 3.0 (hub present)
(2) bottom, (1) side
(3) USB 3.0 Type-A (downstream)
(1) Type-C (upstream)
(1) Port (side)
Power delivery (PD) 65 W via USB Type-C (maximum)
Type-C specifications
USB Type-C port (hub present)
USB 3.1 Gen 1/5 Gbps
(1) Type C (upstream and downstream)
The USB Type-C port can also function as a USB downstream port when connected to a USB Type-C source device.
USB-C Alt mode – DisplayPort 1.2 (video support)
5 V/5.25 V/9 V/10 V/12 V/15 V 3 A/20 V, 3.25 A (power output)
65 W
Ergonomics
Specification
Color (factory calibrated)
Black
Detachable stand
Yes (ships detached)
Cable management
Enhanced cable management for easy concealment of power, video, and USB cables
Display height adjustment
Adjustment range
120 mm
Minimum (desk to bottom of display)
39 mm
Maximum (desk to bottom of display)
159 mm
Tilt
-5 to +20° vertical
Swivel range
45° Left to 45° Right
Security lock-ready
Yes
VESA mounting
Yes, 100 mm
Power
Specification
Power supply
Internal
Input power
100-240 VAC at 50/60 Hz
Maximum power
195 W
Maximum Power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Typical power
80 W
Default Power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
Energy saving/standby mode
0.5 W
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
89.55 x 24.80 x 55.87 cm (35.26 x 9.76 x 22.0 in)
Unpacked without stand
89.55 x 10.42 x 39.95 cm (35.26 x 4.10 x 15.73 in)
Packaged
106.0 x 45.2 x 55.5 cm (41.73 x 17.80 x 21.85 in)
Unpacked with stand
13.8 kg (30.42 lb)
Packed
21.0 kg (46.30 lb)
Head only
9.8 kg (21.61 lb)
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
38.7°C maximum wet-bulb
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
Low halogen
Yes (except cables)
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
Certification and compliance
Specification
Certificate and compliance
Microsoft WHQL Certification (Windows 10, Windows 8, and Windows 7)
SmartWay Transport Partnership (NA only)
CE
CB
KC/MSIP/Mexico CoC/PSB/ICES/TUV-S/ISO 9241 -307/EAC/cTUVus/PSE/ISC/CCC/CEL/CECP/SEPA/VCC I/FCC/BSMI/Vietnam MEPS/Australian-New Zealand MEPS/WEEE/BIS/ErP/E-Standby
Compatibility
Compatible with platforms using the VESA standard video modes
Recommended for use with HP products
Zero Bright Dot Guarantee
Yes
The HP Pixel Policy allows no bright sub-pixel defects for this display.
What's in the box?
Specification
Accessories
(1) AC power cord 1.9 m (6.2 ft)
(1) DisplayPort 1.8 m (5.91 ft)
(1) HDMI 1.8 m (5.91 ft)
(1) USB Type-C 1.8 m (5.91 ft)
Documentation
CD
Documentation
HP Desktop Assistant (with CD)
User guide languages
English, Arabic, Simplified Chinese, Traditional Chinese, Czech, Danish, Dutch, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Brazilian Portuguese, Russian, Slovenian, Spanish, Swedish, and Turkish
Warranty languages
Country: Flag Serbia
