Samsung MFP SCX-4621, Xpress Color MFP SL-C480 - ID Card Copying
The printer can print two-sided originals on one sheet. The printer prints one side of the original on the upper half of the paper and the other side on the lower half without reducing the size of the original. This feature is helpful for copying a small-sized item such as business card.
The original must be placed on the scanner glass to use this feature.
If the printer set to Eco mode, this feature is not available.
Depending on the model, the operating procedure might differ.
  1. Press ID Copy on the control panel.
  2. Place the front side of an original facing down on the scanner glass where arrows indicate as shown, then close the scanner lid.
    Figure : Scan front side
  3. Place Front Side and Press [Start] appears on the display.
  4. Press (Start). The printer begins scanning the front side and shows Place Back Side and Press [Start].
  5. Turn the original over and place it on the scanner glass where arrows indicate as shown, then close the scanner lid
    Figure : Scan back side
  6. Press the (Start) button.
    Figure : Output
    • If users do not press the (Start) button, only the front side will be copied.
    • If the original is larger than the printable area, some portions might not be printed.
