Samsung Laser Printers - Use the NFC feature to print from a mobile device
This document provides information on how to use the Near Field Communication (NFC) feature on Samsung printers to print documents from an Android mobile device.
The NFC feature is available only on select Wi-Fi printer models. To add this feature on a wireless networking printer, you might have to contact the purchasing point to order a wireless/NFC kit, and then install the kit using the Installation Guide.
Follow these steps to use the NFC feature on the printer:
