Samsung MFP Printers - Scanning with Samsung Easy Document Creator
Samsung Easy Document Creator is an application to help users scan, compile, and save documents in multiple formats, including.epub format.
  • Available for Windows OS and Mac OS users only.
  • Windows XP Service Pack 3 or higher and Internet Explorer 6.0, or higher, is the minimum requirement for Samsung Easy Document Creator.
  • Samsung Easy Document Creator is installed automatically when you install the printer software (see "Samsung Easy Document Creator" in your printer's User Guide).
1
Place a single document face down on the document glass and then close the document feeder, or load the documents face up into the document feeder (see "Loading originals" in your printer's User Guide).
2
From the Start menu, select Programs, or All Programs.
  • For Mac: Open the Applications folder > Samsung folder > Samsung Easy Document Creator.
  • For Windows 8: From Charms, select Search > Applications folder > Samsung folder > Samsung Easy Document Creator.
3
Click Samsung Printers, and then start Samsung Easy Document Creator.
4
Click Scan () from the home screen.
5
Select the type of scanning, or a favorites, and then click Start.
6
Make adjustments to the image, as needed: Scan Settings > More Options.
7
Click Scan, to scan a final image, or Prescan, to see another preview image.
8
Select: Save to Location, Send to E-mail, or Send to SNS.
9
Click Save (to save the scanned image), Send (to email the scanned image), or Share (to upload the scanned image).
10
Click OK.
If there is room on the document glass, you can scan more than one item at a time. Use the tool to make multiple selection areas.
