HP Pavilion x360 - 11-ad028tu Product Specifications
2LS11PA
Intel® Core™ i3-7100U (2.4 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
128 GB M.2 SSD
11.6" diagonal HD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 3 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
29.5 x 20.15 x 1.93 cm
1.39 kg
45 W AC power adapter
2-cell, 37.2 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
