Document ID: c05635319
Version: 1
Advisory: HP EliteBook 1040 G4 Notebook PC - The Computer Will Not Power on When AC Adapter Connected to USB-C Port 1 if Battery Charge Is Below 1%
Release date : 10-Aug-2017
Last updated : 10-Aug-2017
DESCRIPTION
If the battery charge level falls below 1%, USB-C port 1 will not recognize the AC adapter and so the computer will not power on (but it will charge). The computer can be powered from USB-C port 0 or, using port 1, after the battery charge rises above 2%.
Figure : USB-C Ports 0 and 1
USB-C Ports 0 and 1
SCOPE
Computers:
RESOLUTION
Wait until the battery has charged for at least 2% (takes about 1 minute) and then the computer can be powered on with the charger connected to USB-C port 1 (or port 0).
Move the AC adapter to USB-C port 0 and the computer can be powered on even while the battery charge is below 2%.
Hardware platforms affected : HP EliteBook 1040 G4 Notebook PC
Support Communication Cross Reference ID : IA05635319
