Samsung Laser Printers - Printing to a File (PRN)
Sometimes it is necessary to save the print data as a file.
Do the following to create a file:
1
In the Print window, check the box next to Print to file.
2
Click Print.
3
Type in the destination path and the file name, and then click OK.
For example, c:\Temp\file name.
If you type in only the file name, the file is automatically saved in My Documents, Documents and Settings, or Users. The saved folder may differ, depending on your operating system, or the application you are using.
