HP Pavilion - 15-cc528tx Product Specifications
2EF25PA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
2 TB 5400 rpm SATA
15.6" diagonal FHD IPS BrightView WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
37.8 x 25.21 x 1.99 cm
1.91 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect
