    Windows 11 Upgrade Guide
Document ID: c05617028
Version: 1
Advisory: HP USB-C Travel Dock - the Dock Connecting Cable Can Be Damaged by Improper Use
Release date : 28-Jul-2017
Last updated : 28-Jul-2017
DESCRIPTION
Improperly bending (twisting) HP USB-C Travel Dock cable (twisting it) can damage the cable.
Figure : The cable is twisted and may sustain damage
SCOPE
Dock:
RESOLUTION
Avoid excessive bending or twisting of the cable. HP recommends leaving it straight and flat to avoid possible damage.
Figure : Cable is flat and straight (recommended)
Hardware platforms affected : HP USB-C Travel Dock
Support Communication Cross Reference ID : IA05617028
