The Samsung Easy Printer Manager is available for Windows and Mac OS users, only. For Windows, Internet Explorer 6.0 or higher, is the minimum requirement for Samsung Easy Printer Manager.
note:The screenshot shown may be different, depending on operating system you are using.
1
Printer List
The printer list displays printers installed on your computer and network printers added by network discovery (Windows only).
2
Advanced Settings
The advanced user interface is intended to be used by the person responsible for managing the network and the printers.
3
Application Information
Includes links for changing to the refresh, preference setting, help, and about.
4
Printer Information
This area gives you general information about your printer. You can check information, such as the printer's model name, IP address (or Port name), and printer status.
note: |
5
Quick Links
Displays Quick Links to printer specific functions. This section also includes links to applications in the advanced settings.
note: |
6
Contents area
Displays information about the selected printer, remaining toner level, and paper. The information will vary based on the printer selected. Some printers do not have this feature.
7
Order supplies
Click on the Order button from the supply ordering window. You can order replacement toner cartridge(s) from online.
