Samsung Laser Printers - How to Access Management Tools
Samsung provides a variety of management tools for Samsung printers.
  1. Make sure the printer is connected to the computer and it is powered on.
  2. From the Start menu, select Programs or All Programs.
    • For Windows 8, from the Charms, select Search>Apps.
    • For Windows 10 / Windows Server 2016:
      • From task bar, type in Samsung Printers in Search input area. Press the Enter key.
      • From the Start icon , select All apps>Samsung Printers.
  3. Find Samsung Printers.
  4. Under Samsung Printers, you can see installed management tools.
  5. Click on the management tool you desire.
  • After installing the driver, for some management tools, you can access them directly from the Start menu>Programs or All Programs.
  • For Windows 8, after installing the driver, for some management tools, you can access them directly from the Start screen by clicking on the corresponding tile.
