Samsung Laser Printers - How to Print a Network Configuration Page
A Network Configuration Report shows the following information:
  • Network Interface Card
  • IP Assignment
  • Ip Address
  • Subnet Mask
  • Default Gateway
  • Mac Address
Do the following to print a Network Configuration Report:
  1. Power On the printer.
  2. On the printer control panel, press the Menu button until System Setup is displayed, and then press the OK button.
  3. Press the directional pad, left or right, until Report is displayed, and then press the OK button.
  4. Press the directional pad, left or right, until the Network Config. or Network Info. is displayed, and then press OK.
  5. Select Yes, and then press OK to print.
