    We are upgrading our website
HP ENVY - 17-ae007ur Product Specifications
1ZB10EA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
  • Discrete
1 TB 7200 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.6 x 28.3 x 2.33 cm
3.04 kg
65 W AC power adapter
3-cell, 55.8 Wh Li-ion
HP Wide Vision FHD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
1 month trial for new Microsoft® Office 365 customers
