HP Enterprise M607-M609, HP LaserJet Managed E60055-E60075, E60155-E60175 - Clear paper jams in the rear door and fuser area - 13.B
13.B2, 13.B9 rear door and fuser area paper jam
Use the following procedure to clear paper jams in the rear door and fuser area. When a jam occurs, the control panel displays one of the following messages and an animation that assists in clearing the jam.
  • 13.B2.XX Jam in <cover or door>
  • 13.B9.XX Jam in Fuser
  1. Pull Tray 2 completely out of the printer by pulling and lifting it up slightly.
    Figure : Removing Tray 2
    Removing Tray 2
  2. Remove any jammed or damaged paper.
    Figure : Removing any jammed paper
    Removing jammed paper
  3. Reinsert and close the tray.
    Figure : Closing the tray
    Closing Tray 2
  4. Open the rear door.
    Figure : Opening the rear door
  5. Remove any jammed paper.
  6. Remove the fuser by grasping the two side latches and pulling the fuser straight out of the printer.
    CAUTION: The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
    Figure : Removing the fuser
    Removing the fuser
  7. Remove any jammed paper from the fuser opening.
  8. Reinstall the fuser.
    Figure : Reinstalling the fuser
  9. Raise the secondary transfer assembly and look for any paper or fragments underneath.
    Raising the transfer assembly
    Raising transfer assembly
  10. Lower the Tray 2 Roller Access Cover.
    Figure : Lowering the roller access cover
  11. Verify that the Tray 2 Separation Roller is securely against the right side of the roller shaft.
    Figure : Separation roller
    Verifying position of separation roller
  12. Close the Tray 2 Roller Access Cover.
  13. Close the rear door.
    Figure : Closing the rear door
