HP Pavilion Power - 15-cb011tx Product Specifications
2BE91PA
Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
Video graphics
  • NVIDIA® GeForce® GTX 1050 (4 GB GDDR5 dedicated)
  • Discrete
  • 1 TB 7200 rpm SATA
  • 256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal 4K IPS anti-glare WLED-backlit (3840 x 2160)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
37.8 x 25.22 x 2.41 cm
2.21 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect
