HP Pavilion x360 - 15-br014ng Product Specifications
2GS19EA
Intel® Core™ i5-7200U (2.5 GHz base frequency, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 headphone/microphone combo
37.78 x 24.58 x 2.03 cm
2.14 kg
45 W AC power adapter
B&O PLAY; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Sure Connect
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
